Giotto Premium Plus (approx. 2009 model) turning off after 10-15mins
  • #16
    I agree, your thermal cut out is working (this is the black thing on top of the boiler with the red button that pops out if there's an overheat situation). If it's working the button doesn't pop out. Don't worry about Ohms - just need continuity when the button is down. If you pull it up you will sever the circuit and get O/L on your DMM.
    Sounds like a bad controller. If you're interested in having a look you can remove the PCB and take a look inside. Sometimes there's carbon around a bad relay or a burned out transistor/TRIAC. Possibly the transformer. Some people here on CS refurbish them. You can put out a request - heck, if it's a heating element relay you could solder a new one in yourself if that's in your repertoire.
    Otherwise site sponsors Talk Coffee and ECA have controllers. I replaced a Giotto controller with a Pro El Ind. earlier this year.
    • #17
      Addendum: that was from ECA (Espresso Company Australia) - the coffee company I was working for at the time had an account with them.
      • #18
        Thanks again Sprezzatura! I see what you mean now about only looking for continuity. I had initially thought that the themal cut out device would vary resistance based on temperature but it did just stay within a very low impedance range, for all intents and purposes, full continuity. I'm guessing once it gets to a pre-determined temperature it becomes O/C (as simulated by pulling the red button).
        I removed the Pro.El.Ind controller last night after taking some "before" photos and labelling each connection. I have found the appropriate transformer and large black relay on RS Components...haven't looked for the transistor yet. Before I ordered the parts I wanted to do a multimeter test after it "turns itself off" and see if the transformer is faulty (i.e. not showing the correct secondary voltage)...only problem is that since removing and re-installing the controller the problem hasn't re-appeared!!! Haha!!! Further testing to come :-)
        If all fails, I'll be planning a trip to see Chris @ Talk Coffee for sure. I would have done so sooner except we live quite a drive from Melbourne so I'm trying to be more self sufficient :-)
        • #19
          Jonny,
          Maybe it's the electrician coming out in me, and the memories of my last little tingle are still fresh in my mind, but you need to be very careful where you stick your test prongs, the wires and terminal your playing with will have 240v on them when your machine is on and running, you must also have a different multimeter to me, mine doesn't like to measure resistance while having voltage applied to it, you won't get a correct reading, and you can also damage your meter.
          I'm all for tinkering and fixing your own problems, but we need to be careful when giving advice to people, we think we may of explained it correctly, but it is easy to misunderstand what is being instructed, I have seen some scary stuff when it comes to electricity and people who think they know what there are doing, it doesn't take much to hurt yourself, someone else, or do more damage to your machine than it already has.
          Not trying to step on any toes here or upset people, just wanted to bring it to your attention, be careful. Sorry I can't offer any help with your machine, hope you get it sorted out soon.
          • #20
            Yes, Tony's correct. I usually don't delve too deep into the electrical diagnosis but if someone seems competent there are some simple tests you can do with your DMM. I try not to do too much with the machine hot myself. The TCO is something that can be tested with no load on as well as coil tests, earth leakage, and bi-pole switch function. Please remember it is 240VAC 10amp and one slip with conducting material and you'll being doing the 240 volt shuffle. You may blow up the board. I suggest having a portable residual current device to plug into unless you have one installed on your mains power.
            On another note, removing the PCB and connections may have jostled one of the relays. If the transistor was blown it would not have improved the function of the h.e. relay. It's a good bet it's the relay.
            • #21
              Originally posted by tonyh View Post
              Jonny,
              Thanks for the words of warning Tony, appreciated and yes I was very careful. I have an electronic engineering degree but haven't dabbled much with electronics in recent years so it has been good to get back into it...cautiously :-)
              So a quick update from this morning, the machine eventually did turn itself off and I then checked the voltage on the secondary winding of the transformer and it was approx. 1V (prior to shutting itself off it was reading 12V - which matches the "no load" output voltage of the 9V transformer). So at this stage I am thinking it is more likely the transformer that's at fault, but happy to take other opinions.
              In the mean time I have ordered a replacement transformer and relay from RS components as they were pretty cheap (<$15 including delivery).
              • #22
                Totally agree Sprezzatura and I always exercise the utmost caution when working on any 240V circuit. Yes, the house does have an RCD but I'm hoping I won't be testing it...but glad to know it's there. Famous last words!!
                • #23
                  Great news, it's fixed. Replaced the transformer and all was well in the world. I couldn't find the exact part number so just made sure it was 240V primary, 9V secondary, 1.5VA and single output. The model I chose was 9 V ac 1 Output Through Hole PCB Transformer, 1.5VA purchased through RS components. RS stock number is 732-0342.Total cost was $6.51. Much cheaper than a new controller board :-)
                  HUGE THANKS to all those who offered support & advice through this forum. That means you Sprezzatura, TonyH, Dumiya & Marke! I really appreciated your time in responding to my calls for assistance and as a result I learnt a lot.
                  NOTE: As mentioned quite correctly by TonyH, anyone attempting this repair should have sufficient competence, exercise caution and take necessary steps to ensure that power is isolated prior to working on the machine due to the risk of electric shock. If in doubt, send the machine to a trained technician.
                  • #24
                    Pleased you got it fixed! Your back to the world of awesome espresso again!
                    • #25
                      Great outcome, always satisfying when you can put your skills to work and solve problems using them, and at minimal cost too, enjoy your next brew.
                      • #26
                        Nice work! Nothing like NOT having to buy a new PCB if you can get away with it.
                        • #27
                          Good work, lacking the technical expertise I simply replaced the whole controller. I took pictures before of the wiring and carefully followed the photo. Doubled checked, Yes I got it right. Even this way is not for the feint hearted. And like wise all is good but it cost about 50 times more than your transformer .... Ah well, good outcomes all round and in the cup!
