Hi CSers
I've upgraded from my Silvia with a used Rancilio S26 from another CS member and trying to set it up this weekend.
I'm having a bit of trouble reliably drawing water into the the machine & wondering if anyone has suggestions on what's going on.
At the moment, I've set up an external water tank to feed the S26. I don't want to drill through the counter top just yet to plumb into mains and have read that running from a tank is commonly done successfully. There's a pressure adjustment screw on the rotary pump to increase pressure accordingly if not running on mains pressure.
The machine pulls water from the tank easily when first switch on, but once the machine gets hot it won't reliably pull fresh water and instead will sometimes let boiling water/steam comes back through the inlet hose (hose gets too hot to touch). I've elevated the tank temporary but without seeing an improvement. It doesn't seem to be running the pump backwards but hot water and bubbles of air are moving through the hose and giving gurgling sounds at the tank. You can hear it at the end of this short video: https://www.youtube.com/watch?v=tHCv4TACW3Q
In this second video, you can see the machine pull water fine at the beginning, then stop and be unable to draw any more water (to refill the boiler): https://www.youtube.com/watch?v=SXuGBmLzKaM
I'll try to rig up a temporary mains connection but knowing others have run from tanks makes me think the issue is elsewhere. Is the pump misbehaving, a valve not closing or something else?
