Hi all
I have an ECM Giotto Classic that is now over 11yrs old, recently it started to have steam come out of the group head so can't make a coffee. I have a pressurestat but have not installed this as yet, will the problem I have described be this or will there be another issue somewhere? The machine definitely sounds different when in this mode. Whilst the machine is apart I'll remove the boiler level probe to check that as well, will this be a matter of cleaning or will that need replacing? would it be advisable to remove the boiler completely to clean out thoroughly?
As a side note some time ago I bought all the parts to refurb the group head (seals, springs, valves, gaskets). With the Classic currently unused I went ahead & pulled the group head down, cleaned & replaced all the relevant parts. Gotta say that the mushroom was nowhere near as bad as I thought it was going to be. Some scale but a good soak in descaler & a good rub down cleaned it up nicely. Scouring the web I saw many examples that were much worse than mine & nowhere near the age. Must have been the use of filtered water for the first 6 years.
Peter
Peter
