Butterfly pressurestat thread
  • duncanbourne
    At home now and remembered I had a broken one in the shed; you are correct, 13mm approx across the widest part of the threads. Thank you.
  • coffee_machinist
    It will almost without a doubt me 1/4", which has a diameter of about 12mm for a male thread. However, if it's wrong, send it back and get the right one. Often there are clearance issues when using thread adaptors and a pressurestat has live terminals, plus small size BSP fittings are pretty hard to find. The Tubefit range that Masters usually stock is reasonable but pricey, bunnings generally have nothing below 3/8"
  • noidle22
    Yea, the 1/8" pressurestat is pretty rare, most machines use a 1/4".
    If it turns out to be wrong, all you need is a cheap brass adapter for a dollar or so from Bunnings.
  • duncanbourne
    Thanks, saw they had both and didn't want to order the wrong one.
  • noidle22
    Pretty sure it's a 1/4", replacement can be found here: 1/4 inch bsp ma-ter pressurestat - Pressurestats | Coffee Parts
  • duncanbourne
    started a topic Butterfly pressurestat thread
    Does anyone know whether the thread on the ma-ter pressurestat in the La Scala Butterfly is 1/4 in or 1/8 in?
    Duncan
