Leaks!
  • Leaks!
    Hmm. After removing and descaling a few of the copper pipes in the Brasilia there are a few small leaks - a drop a second or less - from some of the joints.
    Is there a trick to getting these little blighters to seal completely? Should I polish the mating surfaces or something?
    I've done them up as tight as I'm game with some pretty big spanners.
    duncanbourne,
    Welcome along to the wonderful world of commercial coffee machine "re-birthing".
    Any appliance reliant on hot and high pressure liquid (water), will over time cause eventual deterioration/failure jointing material,the stuff that initially prevents liquids (water) leakage,these areas (piping connections) undergo heating and cooling together with varying levels of vibration (all killers of jointing material).
    Most piping in coffee machines is copper,when brand new copper is ductile and tolerant of heat/cooling/vibration,as coffee machines age (with use) copper will be gradually hardened and therefore become increasingly prone to failures (the connection area of piping ,in particular.
    When you removed the piping for cleaning /descaling,had you considered returning the copper itself to it's former levels or ductility and tolerance of heat/cooling/vibration by "annealing",most likely not.
    Most people would inspect and believe the piping is perfectly serviceable for reinstalling,most likely it may be ,for a short while at least!! When dealing with such metal piping ,consideration must be given to updated jointing materials (gaskets etc) however,further consideration must be allowed for the possibility that a much shortened service life despite all the effort and work done,sadly this is the risk any new owner of a refurbished espresso coffee should expect.
    "I've done them up as tight as I'm game with some pretty big spanners." would suggest to me the piping is failing,may be fixed with renewed gaskets etc but that's only part of the remedial action necessary,remember short term situation and eventually other leaks/failures can and most likely do occur.
    Initial first aid for your leaking piping is check your gaskets and replace necessary gaskets if not stopping any leaks,be careful not to over-tightening copper piping or you may cause stress fracturing of copper!
    Good luck.
    Mick.
      The quick and dirty way is a turn of teflon tape on the male flare face and a couple of turns behind the flare nut on the back of the female flare.
      The former forms a seal and the latter stops the nut tearing away at the copper pipe. In fact you can always put a couple of few turns tape behind the flare nuts, even when the flare is sound.
      Flares should not need to be so tight that you lift the entire machine off the bench when tightening.
      The correct procedure is anneal the flare, ie heat until a cherry red and let cool naturally. You can do this on a gas hotplate - or better still mapp gas or oxt acet torch - hold the pipe with pliers.
      The reason you are having problem is probably because copper has work hardened, likely having been removed and replaced a few times.
      Tightening flare connections until your eyes water seldom fixes leaks. But it can split the flare.
      Good luck.
        A tried and true technician solution for most annoying small leaks.
          duncanbourne,
          After having stated what is ideal regarding repairing used commercial coffee machines,I also have gone your way with similar machines,I'm up to number six.
          Machines were collected in various state of repair,it is so satisfying getting them up and running again,moved one on to new owner however,remaining are spread through staff rooms etc,very appreciated by all.
          rrm recommendations are sound and I too would encourage the application of teflon (great stuff) tape,especially high temperature jobs,with consideration to annealing,fiddly but easy to do.
          How has the rest of your machine coped with it's rebuild?
          Mick.
            Works very well, although I now tend to use Wurth Pipe Seal instead since most of our consumables are now ordered via Wurth. I do carry teflon tape but very rarely use it, due to the risk of stray bits of tape causing blockages through a machine. The only time I use it is when it's the only way to get a threaded fitting to seal where the fitting has to be fitted pointing in a particular direction (such as a right angle fitting at the top or bottom of a heat exchanger) so cannot just be tightened down until it seats.
              There's some heavy-duty, high-temp Loctite stuff that's great for grinder threads that comes with a handy brush in the lid- this stuff is golden (but $$)
                I smear this in steam wand internals and on brazen on flares and ferrules.
                  It's rated to 400° ... so, no heat issues.
                    Ever try the yellow gas PTFE TAPE, Morgan? It's pretty good for those position-specific fittings like injectors at the base of a HX machine.
                      Just feel very sorry for the next technician that meets a joint with that particular sealant.
                      It is a permanent seal. And works the same a loctite if it gets on any thread.
                      The "first" technician may love it, but subsequent technicians will hate it.
                      I'd always use a non hardening sealant if possible.
                        It's not a permanent sealant. I remove threaded carriers, clean them with metho and apply it again. The only permanent sealant is rancid coffee oils that seize the threads on grinders that do not get adjusted or cleaned as often as they should.
                          The 58-11 comes off with very little effort. I've been using it on dozens of machines here for 5 years.
                            The plumber who plumbed t our new house (12 months ago) used it on the garden taps. I had to use oxy to heat the sockets to unscrew them. A risky practice when the piping is polyethylene.
                            It's bad news because it is a Methacralate anaerobic curing adhesive (same as locktite)- I'd suggest a non hardening sealer.
                            MDS: http://www.loxeal.com/files/5811e.pdf
                            For general use (not coffee machine) I use stag or hawkins pastes. Both old fashioned and proven.
                              I'm always happy to try something new. If Stag paste works better and is less expensive (58-11 is not cheap!) I'll give it a go. Where can I find it?
