Hi there. I need some advice re Rocket Giotto . This morning I turned the machine on , heated up fine but there's no boiler pressure. Turning the machine on and off didn't do anything. Any suggestions please.
Not 100% sure what 'heated up fine by there's no boiler pressure' means (i.e. there's no steam? or the gauge just isn't moving or what?) Could be false pressure if valve is sticking. Try opening the steam valve, letting any steam out, then (leaving steam valve fully open) turn off, turn back on again 15 or more minutes later. Someone else will have a better idea than me.
Experts will chip in.
You believe the boiler did heat up? You presume there was water in the boiler? Did you get hot brew water when you lifted the extraction lever. That would prove the boiler did heat up. If it did I expect it was the anti vac valve not releasing the vacuum in the boiler which was created when the boiler cooled from last use - I don't quite understand this. If it was cold then it suggests the switches in the module are faulty.
It might be something as simple as a dodgy pressure stat but it requires qualified diagnosis. If it was my machine I would be talking it to a skilled coffee machine technician and consider it getting serviced professionally while it's there.
ok, so I just turned the machine on with the steam valve and water tap open. It actually made pressure. it's working fine ATM . I can hear the odd hiss though. is that the anti vac valve ??
Sounds like it (i.e. sounds like the problem this time was a sticking valve). Not sure about the hiss....could be the pressurestat. Probably time for a service when you can book it in. One of the experts will undoubtedly see this and comment.
Yep. The hiss is the anti vac valve. I'd still be taking it in for a service but I wouldn't be surprised if the antivac is replaced (it only costs about $13).
