New to Bezzera bz99
  • New to Bezzera bz99
    Hi I've just got my first Hx machine and having problems with crema and grounds at the bottom of the cup.
    Had a rancilio before and didn't seem to have any problems with that machine.
    I've been using fresh beans but crema seems to dissipate quickly. Don't seem to get a nice viacuous shot?
    Also noticed the grounds at bottom of cup now as well?
    Any suggestions? Thanks!
    Using the same baskets?
    I got rid of the baskets that came with my BZ99s and got some EP precision ones.
    Watch you don't overdose the basket - the shower screen sits quite low relative to the group seal.
      I used to get the same with a BZ99, but frustratingly can't remember how I fixed it. It might have been changing the grinder from a Porlex to a Preciso, it might have been thoroughly cleaning the machine (I bought second hand), it may have been new baskets (those from coffeeparts).
      Crema disappears quickly on beans which are too fresh.
        Thanks. Mr jack I'm still using the bezzera baskets so maybe I should change. I've just started trying to use my old rancilio basket and that seems to be working okay but prob could brew a little slower still so I might try to go finer or up my dosage. Had it recently serviced and clean so should be working perfectly. I'm using a compak k3 which I got recently, an upgrade from the smart grinder.
        Still getting little grinds at bottom, not sure why
        also I've noticed that crema looks really nice in the doubled wall small glass I use?
        whereas I use my acm coffee cups the crema seems to dissipate quickly.
          Do you wash them in the dishwasher?
            Trap for young players...
              Hi there. Grab a basket from chris at talk coffee. The prescision ones are a great inporvement over thr bezzera ones. Also get a tamper to match 58.5mm i think. I love the bz99 simplicity. You will be making great coffee in no time.
                Thanks all! Will have to get a new basket and give it a go.
                It is washed in a dish washer. Does that make a difference?
                  I never wash any of my coffee equipment in detergent in the sink or dishwasher, including cups and glasses. It usually leaves behind a small amount of residue that can affect taste. I wash all my coffee gear in hot water in the sink. It's a personal choice, and ultimately its up to you, but it's what I'd recommend if you're serious about making good coffee.
                    Do you also chemical backflush with hot water only? Hot water alone will not remove all the coffee residue. Dishwashers on the other hand are very good at dissolving coffee oils. Any remaining dishwasher residue will rinse off easily if you are worried. (Hand dishwashing detergent however, is only marginally better than hot water at cleaning coffee but is also easy to rinse off.) I personally would rather the 'memory' of dishwasher detergent on my coffee gear than actual old coffee oils going rancid.
                      I'm not stupid, of course I backflush with detergent, but I use detergent specifically designed for the process. I also soak filter baskets and PFs at the same time then I 'season' my equipment afterwards with a waste shot.
                      Washing cups and equipment in (very) hot water in the sink after use will remove all coffee oils if done properly. It means I have control over the situation whereas the dishwasher is an unknown and the outcome is dependent on what detergent and rinse aid is used and how good your dishwasher is. I'm a clean freak, ask my wife, so there's no way I'm using anything less than clean. And I definitely don't want detergent residue in the mix but hey, if you like the 'memory' of dishwasher detergent with <ruining> your coffee that's your prerogative I guess.
                        One of my old organic chemisty professors once explained the issue with dishwasher detergent; although his interest was in maintaining the head on his beer.
                        My memory is a little hazy, but as I recall it was actually that the rinse aid changes the surface charge on the cup - this causes the surface to repel water slightly, making it easier to dry. For the same reason, plastic feels a bit greasy when washed in the dishwasher.
                        Altering the surface charge wreaks havoc on foams or emulsions - and crema is both!
                        It was suggested you could rinse things in fabric softener to reverse the surface charge.
                        I prefer to hand wash my coffee cups (it's better for the glazing too).
                          Of course both dishwasher detergents and espresso cleaners vary, but they typically contain very similar ingredients. Why do you season afterwards? To mask a residue left behind, or to replace some coffee residue that the normal hot water wash doesn't remove?
                          I once acquired an old portafilter that had a buildup of coffee grime. After hand washing failed to shift it, my next move was to try soak it in boiling water for half an hour. That removed a bit more, but there was still a lot that didn't come off. My conclusion was that hot water (and hand wash detergent) is not enough to remove coffee buildup.
                          The surface tension of the water gets lowered, allowing it to drain off easier, and also to form a thin film rather than droplets so it evaporates quicker. If plastic is feeling greasy then you are using too much. You don't actually need to use any, you will just get a bit of mineral deposits left behind, the same as with a water only hand wash.
                          If it makes you feel better to not use the dishwasher then by all means don't, but don't go spouting "dishwasher=bad" without some actual evidence.
                            Do you wash all your coffee equipment in the dishwasher? Whatever that may be - portafilters, filter baskets, French press etc?
                              *cough*
                              Rinse aids are not recommended for laboratory glassware washing. The Jet Dry type of rinse aid deposits on the glassware hydrophobically and repels the water off the glassware during drying to avoid water evaporating and forming water spots. Many rinse aids are cationic (positively) charged compounds that are attracted to surfaces that repel water. This can leave a surface with the water repelling rinse aid.
                              from
                              https://www.alconox.com/resources/pd...asherguide.pdf
                              I always rinse my glassware before use when washed in the dishwasher, to get rid of the residue (which smells and tastes unpleasant).
