Hi All,
I have an Isomac Tea II which has been great for approximately 8 years, the only part I've had to replace is the power switch.
I plan on giving it a bit of an overhaul and could use some advice.
- Steam valve seems to slacken as the machine cools. I'm in the routine of checking the valve is off before turning the machine on in the morning but I am worried about the potential for boiler contamination. Does this require a new valve or is there a seal?
- I want to replace the silicone hoses and any plastic Y joiners.
- I want to pull a plug from the boiler and check for any scale that has built up.
Can you recommend any other parts to check / replace as routine?
