Buying used rocket Giotto help
  • Buying used rocket Giotto help
    Hi all
    i am considering buying a used rocket Giotto premium plus. 1 full gauge for steam pressure. I am also considering new but my interest is also in the workings of the machine and I am handy with tools and electronics. From reading posts I understand that a relay on the control board can fail but I am comfortable with resoldering a new one and have done these things in the past.
    I was just looking for some advice about this machine. In particular the owner has said they have not used it for 3 years or so but has emptied the boiler. If I assume this was not done then would there be a possibility of corrosion of the boiler or level gauge etc from still water sitting for so long? Also I assume seals would need replacement as they may have dried out etc. as I said I don't mind putting in the hours and in fact that's why I would buy it as I like to have these hobbies.
    Also so is there a way I can check it is an Australian delivered machine and not grey import. Owner can't locate receipt and I want to avoid a grey import for obvious reasons.
    Finally what is a fair price in Australia for a machine that is about 5 years old? Obviously I would insist on removing the covers and checking for rust and everything is operational. Also any hints to look for?
    leon
    Welcome Leon...
    Probably see if you can locate the nameplate model details and serial number.
    Then, contact ECA or another of our Site Sponsors, and they may be able to determine its status for you...
      Thanks Mal,
      Yes i'll do that and hope it comes up good. Thanks for the advice.
      Leon
        Plus One to the old Giottos. Great machines that still give the youngsters a run for their money
          Removed quoted For Sale post
          Welcome Richard...
          Best to keep sale promotions in the 4-Sale Section where they belong mate. Not considered good form...
          Javaphile
          Super Moderator
            Hi Leon,
            The premium plus will be a great get if it has been well maintained and 5YO in good nick should still bring up to $1.5k. It's superior in lots of ways over the earlier premium variant.
            Might be worth getting your local tech to have a look on your behalf as well. If he's repaired Rocket before, he'll have an idea of what to look for.
            I'd expect a machine which hasn't been used for a few years may need a little work to get going, but if it fires up, everything else should be pretty minor and limited to consumables and possibly scale if it's an issue in your particular unit...
            Good luck with the purchase...
              Originally posted by Dimal View Post
              Welcome Richard...
              Thanks Mal....point taken! It did cross my mind although I didn't think it quite constituted an official offer ie: no price, no detailed description etc Can you tell me, is it acceptable to negotiate via the private messaging section of this forum??
                Thanks for your advice Talk coffee - very helpful
                  Hi Leonmok,
                  i was also looking at this machine I think and would have bought it only it was so difficult to arrange to see the machine that I bought another V1 model. I paid $1300 and the machine just had a $200+ service, receipt included.
                  if the one you're looking at is in the parramatta area, I was confident it was purchased locally but like you the fact it was unused for several years concerned me. It's pretty easy to remove the top cover and have a general look around for corrosion, if they let you that is.
                  Ive had my machine for 2 days now, still haven't made a great coffee but my worst has been better than the best from my 6910. One other thing, buy a timer to turn it on each morning.
                    Thanks Robbo1111. sounds like you got a good deal. it prob is the same one you mentioned. I already have a z wave switch ready for the giotto which will mean i can automate on and off times.
                      Hi guys. Just had a look and the owner has not emptied the boiler before it was unused for years. What's the likelihood of corrosion damage to the boiler and parts inside? Also there was significant scale and the pressure gauge never lifted past .5 bar
                      Cheers Leon
                        Ok- will need some work (factor in $200+ I'd reckon for a descale and service) which may require a revision in negotiated buy price. Nevertheless, if it fires up, nothing too major assuming it's in otherwise good nick. If a replacement gauge is required, factor in an additional $75 (if I recall correctly). Sometimes they clear, sometimes they don't....
                          Remember he's in Sydney Chris. Nothing gets done for $200 here. I would suggest $350
                            ....which is why I suggested $200+
                              ........getting old here......I missed the +......
