Rocket Evoluzione V2 steam pressure gauge problem
  • #16
    Good stuff...
    We use a C150 Finest and very happy with it...
    • #17
      Originally posted by TC View Post
      G'day starzz,
      If it's only a gauge replacement, it's a 10 min fix- so hopefully they may be able to do it while you are there. If the issue is due to more widespread scale, yes- it will take some time and you could consider it as a wakeup call to ensure your valued machine gets good water.
      Good luck...
      Hi,
      My machine is doing exactly that...Faulty boiler gauge. Functions as normal but pressure gauge sits at 0.5 when heated and ready to go and 0.2 when cold... Can you please explain howto solved esp a 10min fix?
      • #18
        Ethowie, I can see you have been a member here for a while so apologies if you already know this but TC hasn't been active here for about a year and a half.
        • #19
          Hi 338,
          I've actually never posted until recently when I had the issue mentioned above. Still trying to sort it out.
          • #20
            Hope someone else knows the solution. Good luck hope you get it sorted.
            • #21
              Originally posted by ethowie View Post
              Hi,
              *with machine off and not under pressure *
              Remove faulty pressure gauge and replace with new one. Part should be easy to find. I am sure some pf our fine site sponsors would have it. They may also be able to give you a bit more advice on replacing, if you are unsure.
              • #22
                Or soak the gauge and pipe in descaling solution/citric acid
