Rocket evolution pump issue - I think - HELP
  • Rocket evolution pump issue - I think - HELP
    Cleaned my machine this morning and after putting screen back on it won't draw water into the pump. Turn machine on and pump primes but keeps making noise like it's trying to fill up but won't.
    Green light then flashes. And it tries again continuously.
    Any thoughts?
    Pull lever up for a shot and it does the same thing
    Does the tank come out, if so did you put it back in properly?
    Sounds like a water supply issue
      Check that it wasn't accidentally switched to plumb mode.
        Tried both. Bubbles come into tank when it's priming.
          Can use hot water but not the group head. Could the water pipe have. A blockage possibly? As an alternative question, any recommendations for rocket repairers or services in Perth?
            Don't drain the boiler of hot water while the machine is on in this state as you could cook the element. Best turn it off.
            Service tech required. Dimattina Coffee in Osborne Park sell and service Rocket.
              Seems to have fixed itself overnight weirdly enough..
