VBM Portsfilter Handle
  • VBM Portsfilter Handle
    Been getting frustrated with my portafilter handle. It turns around and the rubber has perished around it. I actually pulled the rubber off this morning and it is like a skin over hard plastic. The hard plastic is cracked and the rubber is all runny inside like treacle.
    Not sure if I'm explaining this properly!
    Anyway, if I look on Ebay for portafilter handles, I see M10 and M12 sizes - does anyone know which size I would get for a VBM?
    I assume the plastic comes off and it's threaded..???
    Picture attached.
    Put the handle in a vice or use vice-grips and turn it off the bolt in an anti-clockwise direction. Then measure the bolt diameter using a pair of calipers. Best way to avoid ordering the wrong diameter
      Thanks - yeah I got it off and it's 10mm so an M10. Thanks.
