I'm having problems with my beloved coffee machine. It was working fine yesterday but today decided not to push water through the group. The pump seems to be working ok and it builds up pressure on the gauge but the water flow bypasses back into the tank.
ive attached a photo that shows a leak between the piece of brass that is attached to the pump and a plastic bit.
Obviously this is probably causing the problem. Is this a common part and can it be replaced simply, or should I go out and buy myself a new lever machine?
