So I've decided to upgrade from ye ol faithful Sunbeam EM6910 to an Expobar Office Control (I like to push buttons) and I received it yesterday. After following the instructions for a first start I flushed water through the hot water wand and the steam wand which works fine. However, when I tried flushing water through the group head nothing came out. The pump turns on and water comes back into the reservoir from the OPV but not at the other end. Any tips on what to check or how to find what the problem might be? Alternatively, can someone recommend a coffee machine service technician in the southwest WA area that can repair this brand?
Problem with Expobar Office Control
- Dec 13
- 956
- Brisbane
- Bulk brew; Pour over; Double Ristretto; Oat Milk Cappuccino or Piccolo
- Send PM
Originally posted by scrawny View PostSo I've decided to upgrade from ye ol faithful Sunbeam EM6910 to an Expobar Office Control (I like to push buttons) and I received it yesterday. After following the instructions for a first start I flushed water through the hot water wand and the steam wand which works fine. However, when I tried flushing water through the group head nothing came out. The pump turns on and water comes back into the reservoir from the OPV but not at the other end. Any tips on what to check or how to find what the problem might be? Alternatively, can someone recommend a coffee machine service technician in the southwest WA area that can repair this brand?
- Dec 13
- 956
- Brisbane
- Send PM
- Dec 13
- 956
- Brisbane
- Send PM
- Dec 13
- 956
- Brisbane
- Send PM
Sounds like an obstruction. Sometimes chemical or scale plugs the solenoid valve under the group. If you're handy you can remove it. The centre hole in the base of the solenoid valve will usually be the culprit.
- Dec 13
- 956
- Brisbane
- Send PM
- Dec 13
- 956
- Brisbane
- Send PM
- Dec 13
- 956
- Brisbane
- Send PM
Ok... so I took the solenoid off and it looks brand new. Couldn't find any obstructions except for what appears to be some chunks of thread tape. Anyway, after reassembling the solenoid valve, I just ran some cold water through the pump and it worked. Just heating up the machine now for another trial. Fingers crossed.
I think that's done it! Thanks sprez for the tip. I'm so happy right now. But wow this machine is powerful. I think this triple hole steam tip needs to be changed for a single. It's heating up my milk too fast.
I'll be jacked up on coffee over the next few days trying to get it right and get used to this beast.
- Dec 13
- 956
- Brisbane
- Send PM
