I have a VBM Super Domobar. I descale every 8 - 12 weeks. After descaling I draw at least three full tanks through to clean out. However after a week or so I note that when I draw hot water out of the hot water wand it is cloudy. If I let the water settle there is a layer of fine granules or sediment at the bottom of the glass. Can anyone tell me what this is? Thanks in advance for any ideas. Spencer.
White sediment in hot water.
This makes sense.
Thanks for your input. I did find an online manual which says flush the boiler regularly to prevent buildup of scale. I shall use the hot water wand more, to warm the cups.Originally posted by artman View PostI have seen the same thing if the water from boiler isn't used. I always use it to warm up cups and it hasn't been an issue. This is ok several machines.
On opening, I found sediment in my boiler which was a type of white sand, I believe, used to insulate the heating element.
My heating element casing had a crack in it and was tripping the earth leakage.
I don't know if this insulation material would come in a powdered form light enough to cloud the water.
And you would definitely have earth leakage issues (assuming you have a safety switch installed).
Unlikely this is what you are seeing but thought I would mention anyway.
