Thanks guys for your responses and the links, very informative reading
Most likely getting the Rocket
Happy holidays to all!
Rocket r58 or Bezerra Mitica PID
Yes Bezzera don't have a dual boiler variant so the PID benefits on this model are very subjective.Originally posted by symphonie View PostBezzera does not make dual boiler machines as far as I know. Mitica top is probably no exception. And it seems there's a consensus here that PID does not give you extra performance on HX.
Mitica vs R58 I'd take R58 any day of the week, but it all comes down to if you need/can justify the cost of a dual boiler or not.
I would imagine pricing is different, but if its a dual boiler PID machine you want the R58 would be my choice here.
Symphonie, if I had money for the Rocket R58 I'd go for that option too :-)
Found this pic of the Mitica Top PID (2016 LED-SWITCH) on a German site.
Specifications:
- TEMPERATURE CONTROL BY PID
- Casing of stainless steel AISI 304, finishes welded edges and hand polished
- HX boiler
- Coffee group E61
- "No burn" steam wand
- ROTARY pump
- Double pressure gauge reading boiler pressure and coffee extraction pressure
- Direct water connection
- Removable water tank capacity Lt. 4
- Capacity boiler 2 Lt
- Filter holder chromed steel diam. 58mm
- Power supply 220 Volt 50 Hz Plug Shuko
- Power consumption W 1350
- Dimensions L320 x P450 x H400 mm
- Weight 26,7 Kg
Accessories: filter-holder for 1 cup, filter-holder for 2 cups, blind filter, i plastic tamper
Back panel now has back lighting on the logo...
Bezzera - Host 2015 - BZ 16 & Mitica with PID @
Rocket R58 - check it out on Talk Coffee's site
Stats
Boiler Capacity brew 0.58L, steam 1.7L
Fresh Water Tank 2.5L tank or plumbed
Voltage 220-240V 50Hz
Power consumption brew 1400W, steam 1600W (Max consumption 1750W)
Dimensions (W x D x H) 31 x 44 x 38.5 cm
Pump Rotary
Weight 29kg
REF: From Talk Coffee's page...
Easy fill via removable plate on cup warmer Drip tray is small- but can be drained in this configuration
Removable PID controller- store in a draw when not required Somewhat fiddly wire serial pin printer cable style connection. Machine must be switched off and on to communicate
Cool touch wands Employs powdercoat chassis unlike the stainless steel of some competitors
Excellent steam tip for easy milk texture
Beautiful Faema style steam and hot water valve handles
Ageless, minimalist designLast edited by matth3wh; 9 December 2016, 11:36 AM.
Hey Matt, thanks for the welcome, I appreciate your comments
The Bezerra is actually a MITICA TOP, PID version as offered by its distro here
It has a dual boiler, rotary pump with temp controlled via PID
I'm in Manila, by the way
There are other brands available here, however the models for sale are either too expensive or have none
of the features that I THINK an espresso machine should have
Any idea what the top selling brands in Australia are far as these machines are concerned ?
thanks
Hi blademan. As it's your first post. Welcome to CS!
Are you located in US?
I noticed that you posted this question on HB.
As far as I know the Mitica PID is not yet available in AU.
And no spec of it that I can find on the Bezzera .it
I have seen mention of it at trade show videos but no more details.
The rocket r58 is dual boiler with PID and the standard Mitica is heat exchanger. Unless the PID version is a departure from that.
I notice Bezzera have a lot more models available around the world than are available in AU.
Let us know if you find anything on the Mitica PID spec.
That leaves the Rocket as the winner based on the two options you've given as least in the AU market. The Rocket should give you better temp stability. Some would argue better build quality and looks too.
Interested to know how you came to these two machines?
Hi guys
Please kindly help me choose between these 2 machines- Rocket r58 vs. Mitica PID
I'm coming from a Delonghi superautomatic and would like to upgrade to a better setup for the house
Please kindly tell me why you would choose one over the other
Thanks all
RegardsTags: None
