Astoria CK Restoration (Warning a lot of photos)
  • #16
    Originally posted by ckanu View Post
    Astoria CK coffee machine worked perfectly until a few days ago, at this moment I have the following situation and I can not find the solution, maybe you can help me. I turn on the espresso machine normally, the boiler starts to rise and when it reaches the right, the red light on the front will turn on and I will not use it, from that moment the boiler will completely cool and return to take temperature until it reaches where it corresponds and turns on the Red light again and so repeat the cycle.
    Thank you very much and greetings from Argentina !.
    Someone can help me with this trouble?
    • #17
      The power relay on the control board is probably bad.
      Due to the age of the machine, it would probably be a good idea to replace all of the main components on the control board. This would be the transformer, relays and the capacitor.
      • #18
        OMG! You're a ninja espresso. I'm going to try this and then tell you if it worked out. Thank you very much!
        • #19
          The machine works great now, thank you very much!
          I recently buy a Faema Lambro... in 2 or 3 weeks i post a restoration treadh about it.
