Astoria CK Restoration (Warning a lot of photos)
  • ckanu
    Originally posted by noidle22 View Post
    The power relay on the control board is probably bad.
    Due to the age of the machine, it would probably be a good idea to replace all of the main components on the control board. This would be the transformer, relays and the capacitor.
    The machine works great now, thank you very much!
    I recently buy a Faema Lambro... in 2 or 3 weeks i post a restoration treadh about it.
  • ckanu
    OMG! You're a ninja espresso. I'm going to try this and then tell you if it worked out. Thank you very much!
  • noidle22
  • ckanu
    Originally posted by ckanu View Post
    Astoria CK coffee machine worked perfectly until a few days ago, at this moment I have the following situation and I can not find the solution, maybe you can help me. I turn on the espresso machine normally, the boiler starts to rise and when it reaches the right, the red light on the front will turn on and I will not use it, from that moment the boiler will completely cool and return to take temperature until it reaches where it corresponds and turns on the Red light again and so repeat the cycle.
    Thank you very much and greetings from Argentina !.
    Someone can help me with this trouble?
  • ckanu
    Originally posted by LFM60 View Post
    Excellent restoration work there ckanu. You should be proud of the finished job.
    How did the first shot taste?
    Thanks!
    Really creamy and strong ... I needed to regulate the grinding
  • LFM60
  • LFM60
    I replace all photos to flickr account, now its ok?
    yes, I can see them. Very good ckanu.
  • ckanu
    Originally posted by Javaphile View Post
    You can see them because they're hosted in your/Home-Barista's google account. The rest of us however can not log into that account and as such do not see them.
    Java "No pics" phile
  • Javaphile
    I see all the photos, someone else can not see them?
  • ckanu
    Welcome ckanu and your English is much better than my Spanish. Well done.
    Thank you very much... the translator's magic
  • ckanu
    None of your picture links work.
    Java "Bad links" phile
  • ckanu
  • ckanu
    The first shot (Or some)
    Actual configuration
  • ckanu
    PAINT JOB
    I had to replace the pump because if it worked, there was no water
  • ckanu
