Hi guys, I've come across this forum a while back and wanted to get some crowd advice on what might be possibly be going wrong with my VBM Domobar Super. I have the microswitch unit (not lever or automatic) and last few days my wife had noticed that my steam pressure was dropping off. Initial pressure sits around 1bar then once you get the steam going, drops to 0.4bar and you can tell thats its not enough to stretch the milk.
The heat and pressure coming out of the group head has been fine and honestly, I only noticed myself when I complained to my wife about the poor coffee and asked me to make my own ;-)
I checked the steam, weak, checked the hot water tap, no water (only steam)... Now I realised there was a problem.
This might be karma, but this morning the safety switch was tripped in the house, (left machine on overnight by accident) and the machine now doesn't heat up.
I had the Gicar Controller (refurbished) and element (new) replaced around 6mths ago and immediately thought oh no, another controller/element... $$$$
I opened the unit, pulled the connectors of the element and the element is registering "open" around 20Megs.
Could this refurbished controller have been the culprit? I was told that these refurbished Gicars were perfect. Is there anything else that could be the cause. Could the heat created in the unit be enough to stress the components in the controller and cause failures?
Don't want to go through the process again and spend another few hundred on the unit and the Gicars warranty is for 3mths anyway...
Any advice would be appreciated.
Paul
Paul
