Originally posted by scho047
View Post
New La Pavoni & Fausto
quick question....
i have been using the machine as per my above thread... and it has been working really well. But i have noticed that when I am doing the backflush, the pressure is at 12 bar which has been where it was since the beginning. However when I put coffee into my pseudo 20g basket with correct dose and been tamping to the usual method and then start the brewing process, it only goes up to 4 bar. I had initially thought this was due to bad quality beans but when I switched it back to the good beans when I was getting good consistent 9 to 10bar whilst extracting, it was still at 4 bar (and therefore poor espresso).
what am i doing wrong? or anything wrong with the machine?
I have tested doing a blind extract and it was fine and went up to 12 bar again...... any tips?
I have realised that I was a complete newbie for sure! as I was going backwards with the grind setting.... and therefore what I thought was making the grind to be finer, was in fact making it coarser and hence low pressure and quick extract and sour tasting coffee!!!
All has returned to normality and making great espressos again on my new shiny toy!
Lesson learnt - use good quality fresh beans and when swapping out the beans, grind and throw some out and before panic sets in, learn to check which way I need to turn the grind dials for finer grind or coarser for that matter!
Where are you getting the 12 bar reading. The meter on the front of the machine does not read that high. If you are getting the reading from a meter on the brew head, check with the seller if that is correct. i only have the meter on the front of the machine and it varies from1 to 1.2 bar depending where in the heating cycle the machine is at.
