Lelit Diana PL60T V2 or ...?
  • #16
    Looking good!
    Originally posted by Moph View Post
    Still have to tidy everything up particularly the power strip (need to see if I can install a quad wall outlet)
    A Clipsal C2015D4 quad outlet should mount exactly the same way (to the same bracket, same centre position) as the single you have existing, it's 196mm wide so check it will fit on that section of wall, if so it'll be an easy direct swap out for any licenced electrician. They are pricey though.
    • #17
      Cheers ... under $40 so not too bad. I have an electrical contractor in the family so I'll pick one up and trade him coffee and cake to fit it
      Struggling with the WeMo at the moment. Have set the location to Perth in the WeMo app and power cycled the device but it's still showing the time as AWST + 2hrs. Means none of the in-app data records properly (as that's calculated using the phone time, which is correct) and scheduling isn't going to work properly. Not quite sure what to do other than a full reset and go-round at this point =/
      • #18
        They've halved in price since I last looked, much more reasonable now!
        • #19
          TH test strips arrived today - our unfiltered tap water is ~80ppm and the filtered water is ~20ppm interpolating between the test colours. Haven't fitted the carbon phosphate scale remover yet but looking promising already. Should be very soft once I install the scale remover as well.
          Interestingly the next suburb across from me has some of the worst water in Perth - bad enough that our HWS manufacturer (stainless steel tank) won't warranty any heaters installed in that postcode. Must be on a different branch of the main.
