New Bezzera Mitica Top no pressure at at group head....Helo!!
  • New Bezzera Mitica Top no pressure at at group head....Helo!!
    We have had a new Bezzera Mitica Top delivered today and have set up as per instructions but have no pressure at all at the group head even with the blind portafilter. Machine has been on for over an hour, it is full of water in tank mode but still nothing. Hot water is working fine and also steam. Any ideas???
    Do you get any water out of the group or pump noises when lifting the group lever? I know it's Saturday, but have you tried the vendor yet? Best not to mess around with it too much if its new/under wty
      Also ensure both selectors are in tank mode, there is usually an electrical switch for the low water light behind the drip tray, and also a physical valve under the machine to select tank or plumb mode (looks like a black knob) Make sure the one under the machine is in the right setting
        Thanks for the reply.
        As far as the vendor goes it was Winnings appliances as the price was a lot less than specialty stores. It did concern me a little for this exact reason buying through them but the price was too good to refuse!
        So as far as the issue goes there is no pump noise and after heated up a while a little steam comes out the group head only. There is no pump noise at all. I had a look and there seems to be no switched as suggesed, only a pressure adjustment screw under the machine.
          Milly 3;
          If the machine has not been tested by the re-seller or the importer it could be anything, you can try the follow
          - turn Off and ON the machine this machine when they are new they have a cut off divice to not to over load the pump (This is usually should be done by importer or the re-saler before is been delivery to the customer)
          -Unplug the machine from the main electrical point re plug after 10 sec, this will start the main control
          -take out the water tank and put it back could be the sensor is not recognizing there is water there or the tank is not touching the sensor
          or just give me a call I will trouble should it for you,
          Regards
          Renzo
            What a star Renzo, thats exactly why I purchased my new Rocket from Di Bartoli - fantastic customer service and always willing to offer advice and help. Good on you Renzo.
              Thanks for that Renzo,
              I have tried all as per above still with no success. How can I contact you, at the store?
              Regards,
              Nathan
                Nathan; any luck let me know who do you go
                Regards
                  No Renzo,
                  Tried all that you said with still no luck. Feeling very disappointed.
                  To anyone taking interest in this post I would like to let everyone know that I didn't even purchase off Di Bartoli, Yet Renzo is offering his help and has talked to me on the phone to try and help. This sort of customer service is very rare and is much appreciated.
                    Hi Milly3
                    I understand why you would have been tempted by a "price too good to be true". Who wouldn't be , we all love a bargain, that's just human nature.
                    You are now experiencing the thing that's very hard to put a price on, top notch customer service. Renzo has offered his help at a very busy time of the year for him. Having dealt with him for over 4 years now, it doesn't surprise me at all.
                    I have posted this before and I will repeat it again now, this level of service from Renzo and Ofra at Di Bartoli, is just one more reason I am happy to make the 5 hr return trip to their store when I'm in the market for new gear or taking my machine in for a service.
                    I hope you get this issue sorted soon.
                    Mal
                      may or may not be of use.............Troubleshooting - Fine Coffee Company
                        Regards
                        Renzo
                        You guys are champions...
                          Issue sorted, I got a call from the Barazi today and we worked through a few ideas and found the fault to be a wire was disconnected on the switch that activates the pump. All back together and enjoying a great coffee....
                          Thanks everyone for your help and also Renzo from Di Bartoli.
                            Yeh!! It can happen to the best of them. I had heard previously that Barazi (Australian Bezzera distributor), support their product really well. Good to see this in action. Top Stuff!
                            Time to sit back and enjoy a bloody good machine!
                              Nathan; that's great enjoy your coffee now
                              Regards
                              Renzo
