So my dad's unico splendor has recently had an issue where the brew lever switch would seem to be a bit "sticky" - after pushing the lever back down after pulling a shot, the pump would keep running. If we gave the springy roller thing a flick (pushing it in with a finger and letting it spring back out fast), it would stop - so it seemed there was an issue with the switch not turning off properly. Now it's given up turning off altogether, the switch seems to be always on. Am I safe in assuming it would have to be the brew lever microswitch that would be the issue, given that giving it a flick previously made it turn off? I'm guessing the whole microswitch will need to be replaced unless anyone has come across this issue before and has any other solutions?
Fairly certain it's part 703000 here: https://www.coffeeparts.com.au/bfc-s...rts-7-switches which links to "Group microswitch wega" does this sound right?
