Hello all,
i have a domobar JNR, purchased 2010
its been rock solid until recently.
turned it on the other day and it pumped water for ages and eventually stopped and wouldn't heat.
i could trick the heater to turn on by pulling the lever.
however when i did this and it started to boil, water came out the vac valve
ive check the ground cable to the boiler, its fine
ive removed and cleaned the water probe.
im assuming the control board is pork chopped?
thoughts
thanks
thoughts
thanks
