To be honest Mal, I was never really expecting this boiler to be any good.
When you say certification requirements, you mean the ratings on the sticker on the machine or is there some specific standard relating to coffee machines in general?
Yes mate, the Standards Association of Australia will have the minimum standard that small boilers will have to meet...
Well I think I have found what sealed this boilers fate from the previous owner. A combination of carelessness and poor quality water.
The boiler fill sensor was completely caked with crud, this likely resulted in the boiler overfilling. Check out the gunk! The previous owner appears to have ignored this problem and persisted with the machine until there was probably a large puddle of water under the machine one day
Does anyone know how long the probe is meant to be for the Domobar super?
Reason: More info and fixed the pic
Today I started the process to pull the boiler out, another screw in fitting snapped (with very little force). Corrosion is looking pretty bad, I think a new boiler will be the way to go but I will still test this one out.
About 20% of the way through getting the boiler out, there are some very persistent nuts holding me back!
The E61 lower housing/fitting and the drain plug are missing from the group assembly. Does anyone know if I am able to use the Faema E61 group parts (lower fitting and discharge fitting) in place of the VBM parts? Are the thread sizes the same for the screw in bits?
Below, circled, are the parts I am referring to:
EDIT: it appears I have the discharge fitting! Having never owned an E61 (or really used one for that matter), and having this group given to me in pieces, working out what is what from the exploded parts diagram is challenging! I still need the lower fitting/housing and so that part of my question still stands.
Thanks @CafeLotta! I was actually going to ask about espressocompany.com.au (as in are they a legit resource) given they have not only the complete parts diagrams but ‘sets’ of components I need. Will also get in touch with them
Thanks Mal, I was having a look over some of the exploded diagrams on coffee parts for other E61 groups and noted some subtle differences. It appears these differences are mainly around pre-infusion implementation and other ‘non-standard’ E61 hype?
Anyways, will definitely get in touch with Coffee Parts
Do I have to seek parts specific for the VBM E61 group head assembly or can I use ‘generic’ parts? The parts needed are items such as infusion valve set, discharge valve set, distribution valve set and the lever set (as in the lever itself and the plate it mounts to).
G'day Solace...
Some components are definitely VBM specific but the best person to contact, would be Pedro at Coffee Parts as he should be able to inform you of the correct parts to use. It's not just VBM who do this, by the way...
The Domobar Super was high on my upgrade list with the upgrade slotted in for an upcoming milestone birthday in two years time. Then I found this Domobar Super at a garage sale, the fitting for the tube leading to the solenoid valve had been snapped from the boiler and the previous owner had deemed too hard to seek repair. So $20 later and here I am, about to embark on a restoration journey that will hopefully see me with a fully functional machine I was considering to upgrade to regardless.
There are parts missing from the E61 group head assembly, so I might start this thread with a question:
I will keep this thread updated with all my trials and tribulations plus plenty of nerdy pictures!
I am in no rush to complete this project, so bare with me. I’m sure I will learn loads, hopefully this becomes useful for others in the future.
Here are a bunch of pics of the machine as it sits now, straight from the garage sale to its new home:
