Rocket Giotto
  • Rocket Giotto
    My dear old Giotto is off to the Doctor.
    On start up everything appears normal until you have to use the steam wand.
    The pressure drops right off to zero then takes about 40sec to a minute to build up pressure then all is good and
    everything works normally.
    Any ideas what it might be?
    Sounds like you may have a stuck Anti-Vac Valve...
    Easy to remove, clean and replace O-Ring if needed and inexpensive to completely replace if that's warranted...
