I have read various ideal brew pressures. Mine is measuring 8.5 bar on a pressure gauge fitted to the bottom of a spare portafilla. What do you guys think, is it low ? Is it ok ? Should i leave it or should i adjust it ?
Giotto v2 brew pressure
Mal's right. Provided your technique is right, if the coffee is good in the cup then that's all that matters. Don't rely on your pressure gauge reading other than for troubleshooting faults eg no or very low pressure.
Brew pressure is a balance between temperature and boiler pressure which needs to be adjusted according to your preference and best left to a professional technician with the right equipment. Coffee machines bought from reputable dealers are usually calibrated before delivery to the buyer using a device which tracks temperature and pressure throughout the brew cycle. Once adjusted your machine shouldn't need adjusting again.
Thanks Dimal.Originally posted by Dimal View Post8.5 to 9.0 Bar is perfect...
Just out of interest, if I was to increase the pressure to say 9.5 bar, would that mean that a finer grind would be required to lower the greater water volume in the given 25- 30 seconds due to the heigher pressure ?
And if that was the case, would there be a discernable difference in the cup between the two settings ? I thought I read somewhere that a finer grind as the potential to improve flavours ?
I am happy with whats currently in the cup at 8.5, I'm just interested in the science behind the brewing options.
Yes to the first, Darcy's law applies so flow rate is proportional to pressure for a given permeability and viscosity. Grind, dose and tamping all affect the permeability of the puck which also changes with wetting and during extraction. The CO2 level and extract have the biggest effects on viscosity. Wetting, extraction and CO2 level all change with time during the shot so the flow rate also changes.
The second is more complex. All else being equal, the finer grind (smaller average particle size) at similar flow rates should increase extraction as the surface area to volume ratio increases as the inverse three halves power of the particle dimension. The complication here is that the increase in level of highly soluble things like organic acids will be smaller than for less soluble things like chlorogenic acids for the simple reason that most of the former would already be dissolved.
Only you can tell whether the increased extraction improves the resultant coffee for you. For me increasing extraction tastes better until it doesn't.Last edited by Lyrebird; 14 June 2019, 07:47 PM.
Made the adjustment last night. 1.5 turns in on the opv moved my pressure on the portafilla gauge from 8.5 bar to 10. That should be around 9bar actual. (The blind portafilla reading is typically 1 bar higher than actual head pressure)
I have plenty of finer adjustment remaining on my grinder so will take make it a notch or 2 finer and see how it goes.
