BZ10 owners - request for information on steaming performance
  • #31
    Interesting......I bought the Bezzera 4 hole and 3 hole tip - I too had an issue with the 3 hole tip not being delivered and was refunded in the end.
    The 4 hole tip I found too powerful for the 150ml amount of milk I typically use for a single drink - Just destroyed any chance of good microfoam. It worked okay in a 600ml jug frothing milk for two drinks at the same time.
    The stock 2 hole tip is what I'm still using - I ended up getting good results after taking time to really play around with the steam wand position.
    I bought some other brand tips as well that screwed onto the wand okay, but the diameter of the tip was wider than the steam wand itself, so the steam tip flared out at the point where the steam tip meets the want once screwed all the way in. My OCD couldn't accept this!
    I've gotten decent milk these days, but didn't think to try other tips again to further improve the milk texture.
    I might look up those 2 and 3 hole tips you've mentioned above, thanks!
    • #32
      As an update - ended up blocking one of the holes with a toothpick. Steaming is slightly slower, however quality of the micro foam is better as the boiler pressure staying high really makes a difference in keeping that whirlpool moving well.
