I started descaling, the boiler took the liquid in and started to see greenish water coming out of the spout. I refilled the tank with clean water to start to flush out the descaler.
At this point, the pump no longer fills the boiler. The vibration pump runs silently, for about 2 minutes until the auto shut off timer stops it, but no water goes into the boiler. Both water level sensor shows open. The boiler sounds empty, when I shake it to hear if water is present.
The overheat switch at the bottom did not trip.
When the vibration pump runs, I can attempt to pull a shot, and cold water comes through the group head.
Any suggestions on how to get back normal operation?
Gabe
Gabe
