Grimac Mia Restore/Rebuild - “Greta”
  • Grimac Mia Restore/Rebuild - “Greta”
    So whatwas going to be a day in jammies till when ever i got to garage turned into a mad dash across Sydney, to go meet two vry nice people, an their awesome doggo,
    I now have a Grimac to play with,
    On filling tank an powering up the boilers boiling but I think there maybe oscillating pump issue, its loud as hell then stops with an error beeping sound and on the front pad h what I think is watericon is flashing,
    So after a quick milan photoshoot an testing of that awesome green purple polish, thamls Dimal!!!
    Greta as she has been codenamed, will need her clothes removed and pump looked at.
    Inital pics and man that polish works soooooo well!!
    How good is this purple polish, stainless almost mirror like an i only did a half assed job!
      Now to find a user manual an diagrams!
        And with side panels off
          Good solid machines. There's a water flow issue, first try priming the pump. Use a syringe or blow into the tube that feeds water to the pump to try and introduce some water to it. That may be all it needs to start working again.
          I'd also love to know who applied teflon tape to every flared fitting visible on the machine. Clearly a fundamental lack of understanding. Tread carefully with the rest of it, who knows what else they've done.
            its definetly pump
            just found this other ex5 in my spares box an reading ratings im guessing they arent interchangable?
              noidle your a bloody legend i did what you suggested an its drawing water!!!!
                we have flow!!!
                  Originally posted by Sullo View Post
                  its definetly pump
                  That new pump will be a direct swap for the old one
                    had to go for a shot, time an grind is way off, thinking head needs some love perhaps new seals almost as much water came out the base if the e61 as did the group head!
                    but am happy so far!
                      Was that during the shot or at the end?
                        Amen to that.
                        Amen is basically Hebrew for "Ain't that the truth".
                          The pressure stat in mine is mounted a bit higher up but everything else looks right.Grimac MIA Parts.pdf
                            at the end itd piddle out
                              I always thought it was a greeting for adult males.
