Grimac Mia Restore/Rebuild - “Greta”
  • Sullo
    Just needs a new group head seal an calibrated grinder an i think for the moment Greta is done!
    Cleaned in and out repainted an shiney!
  • Sullo
    Refinishing panels have been painted, wasnt fussed about a few divets might do those again down the track
    But the matte finish i think looks ok
  • Sullo
    Originally posted by robusto View Post
    So it brews, and when it finishes the brewing stops and water comes out of the very bottom near the drip tray? That would be the 3-way valve releasing pressure from the top of the basket so it doesn't explode everywhere when you remove the pf.
    that bit I knew but not the how and how much part, its so damn shiney now thanks to Dimal!
  • Sullo
    Originally posted by Javaphile View Post
    Manual added to appropriate documentation area.
    Java "Grimac Mia exploded view and parts list. Includes parts lists for other models." phile
    You sir are a god!
    Sir Java "humble but damn good"Phile!!
    Steve "worse than a first year apprentice "Sullos
  • Sullo
    I don't have much experience with E61 at home, thought it piddled out a fair bit, either that or the drip trays gonna need emptying a lot, thinking of adding in a removal tube under the tray to external like other commercials have.
    Guessing I have much more to learn! But its still fun so Ill keep at it.
    Seriously that purple stuff for polishing is the bomb, I even polished our entire kitchen sink with it!!!
  • Javaphile
    Originally posted by pjchris View Post
    The pressure stat in mine is mounted a bit higher up but everything else looks right.[ATTACH]23605[/ATTACH]
  • robusto
  • robusto
    I always thought it was a greeting for adult males.
  • Sullo
    Originally posted by level3ninja View Post
    Was that during the shot or at the end?
    at the end itd piddle out
  • pjchris
    The pressure stat in mine is mounted a bit higher up but everything else looks right.Grimac MIA Parts.pdf
  • Lyrebird
    Originally posted by noidle22 View Post
    I'd also love to know who applied teflon tape to every flared fitting visible on the machine. Clearly a fundamental lack of understanding.
    Amen to that.
    Amen is basically Hebrew for "Ain't that the truth".
  • level3ninja
  • Sullo
    had to go for a shot, time an grind is way off, thinking head needs some love perhaps new seals almost as much water came out the base if the e61 as did the group head!
    but am happy so far!
  • level3ninja
    Originally posted by Sullo View Post
    its definetly pump
    just found this other ex5 in my spares box an reading ratings im guessing they arent interchangable?
    That new pump will be a direct swap for the old one
  • Sullo
    we have flow!!!
