A little bit, less destructive than they usually are though
Ahhahhh so i still get to go waste time at stupid cheap auto!
Mainly cos i wasted an hour trying to find the one i thought i had then remembered i loaned it
Who i have no idea!
Have a good week everyone thanks for reading thus far in sullos latest edition of this bugger machine wont beat me!
will the element break free
will he break the element
will there be moaning an gnashing of teeth or knuckles
will the peasants rejoice as threads break their strangle grip on the boiler
and in another useless update, a part I ordered from the UK arrived, and the element I needed from Victoria STILL hasn't arrived.....
Both ordered same day 5mins of each other...
Lucy awaits her new heart...
Soak the hx with citric while you are there too. And it may have restrictors in the top hx pipe, that may need clearing out.
Here is a pic of last one I did...
It looks like your machine is a thermosyphon heated group. So, if you don't have a restrictor in that top pipe, you should get one for it.
What it does is restricts the flow of boiling hot water from the top of the hx, and blends it with cooler water that is in the return loop to the bottom of the hx. A little difficult to tune, but results in a machine that needs much less of a flush.
That blocked restrictor meant that the group would not heat properly (no thermosyphon), and no matter how hot the boiler, the coffee was no where near hot enough, almost lukewarm.
Turns out it is a very nice Diadema for me!
