VBM super corrosion
  • VBM super corrosion
    Hi guys,
    When I descaled my VBM super lever a couple weeks ago I noticed some corrosion on the boiler.
    I don't recall it being there last year.
    How concerned should I be and what course of action is recommended?
    That looks like you have a leaky gasket/seal.
      New element seal needed at some stage... You can brush with citric acid/descaler to remove the crud, and wash off well.
      I couldn't undo my element without stressing every boiler mount, so I pulled boiler and held element in vice and unscrewed boiler. I also chopped as much of the gasket out as I could to reduce the stiction.
      Hopefully yours is no where near as tight.
        Also using an impact driver will remove the element with minimal effort or risk to the boiler.
          Thanks guys, I appreciate the assistance.
            Hello just getting around to ordering the replacement part. Is the correct seal part 460049-t (BOILER TEFLON GASKET) or 400826-t (HEATING ELEMENT TEFLON GASKET 42X54X3MM) shown in this diagram?
            https://www.coffeeparts.com.au/vbm-s...ler-components
            Or feel free to link me elsewhere for the right part. Otherwise I only found the heating element and gasket as a kit.
              Part No. 400826-T appears to be the one you need-
              https://www.coffeeparts.com.au/parts...sket-42x54x3mm
              Refer the link below from CoffeeParts for VBM super parts diagram -
              https://www.coffeeparts.com.au/parts...r-super-boiler
              Have a good look inside the boiler once the element is out. A thorough descale may be needed.
