Bezzera BZ35E volumetric setting adjustment
  • Puss_Puss
    Re: Bezzera BZ35E volumetric setting adjustment
    Thank you Renzo, would you please advise the necessary action to set to factory settings after pressing the centre button? Kind regards........Kim
  • DiBort
    Hi,
    Very easy, press the middle button for about 5 seconds - light will flash and then start programming each buttom.
    For more instruction give a call.
    Best regards
    Renzo
  • Puss_Puss
    started a topic Bezzera BZ35E volumetric setting adjustment
    Can anyone help with an instruction manual for a Bezzera BZ35E? Any sort of copy or internet download would be appreciated as I have no instructions at all. I have just purchased a second hand unit & the volumetric settings appear to require adjustment. The smallest setting, the single cup single shot, almost fills a moderate sized cup & a double shot overflows it. Has anyone struck this before? Might it be that the previous owner has had it adjusted or modified? It was previously used as an office machine & it appears no-one knew how to operate it correctly.
