VBM Domobar Junior brew pressure too high?
  • jchong
    commented on 's reply
    jsnoble - sorry can't help. I think just constant wiggling helped me get it done.
  • jsnoble
    Hey jchong, sorry to resurrect an old thread - but what ended up being your saviour to get the screw to move on your Jr?
    I have the same problem as you - it’s stuck fast. 8 year old machine. I’ve tried wd-40, and a lot of elbow grease (so much that I’ve bent a 10c coin). Any other tips?
  • noidle22
    I should amend this for anyone else scrolling by who might attempt the restrictor mod. Start with drilling the restrictor to 3.5mm and test it first. The ones I've done since this post I've only needed to enlarge to 3.5mm-4mm.
  • termoli
    Originally posted by noidle22 View Post
    Did a Domobar Junior today, with a brand new brew gauge installed, adjusting the OPV to get 9 bar on my scace indicated 9 bar on the machine gauge. They are very close.
    I've also noticed recently that some Domobar Juniors have been running extremely cold at the group which gives a distinct sour taste.
    In the last few weeks alone I've done three of them, all purchased around 2014-2015 and no matter how long I let them heat up, I could only get 75-80C from the group under extraction.
    They have an approx. 1.8mm restrictor in the HX circuit and with the factory set 1.1-1.2 bar boiler pressure, the boiler is only sitting at about 110-112C (normal HX boiler temp with an E61 is around 120C).
    I've had to up the boiler pressure to an indicated 1.5 bar to get 120C at the boiler and drill the restrictor out to 5mm. Once done, the machine is stable with extraction temps tight around 92.5-94C. No cooling flush required either.
    My customers have all bought these machine from box store sellers which I assume is the problem. The other problem is that all three had previously been in for service elsewhere.
    If you have a Domobar that was purchased from a box seller, I'd highly recommend getting it taken to a reputable service shop for an assessment as you could be missing out what the machine can actually offer.
    Yep, I've got one purchased Sep 2014 and for the life of me couldn't work out why the shots have been getting colder. Its been in to three different places but I suspect all they have done is a flush and a polish. If someone can recommend an outfit in Perth that won't get offended when I show them your post as to what is causing my issue, please pass on. Much appreciated, JL
  • sacsnob
    What pressure reading would you recommend at the gauge for VBM junior? TC recommended 10.5 in a post a few years ago and I've seen other people recommend 9.5 too.
    Cheers.
  • level3ninja
    Higher pressure with all other factors the same means higher extraction. The other thing it does is increase the likelihood of channelling.
    If it's not the standard 9bar it should really be included in the recipe, as pressure is one of the factors influencing extraction. Sounds like you did the right thing though, hit the recipe and when it wasn't working went back to the author.
  • anthonypiccolo
    Hey all,
    I just thought I'd follow up on how things have progressed.
    - Grinder was recalibrated
    - Added coffee sensor, ensuring I was brewing at 92-95 degrees. A flush before brewing for around 8 seconds will usually get the grouphead to ~91C so I'm assuming at the puck it would be. around ~93-94. Didn't seem to be a temperature issue though
    - E61 grouphead completely taken apart, cleaned and new pistons added. After doing this the backflush was still not coming through the exit chamber.
    - Added a new cam lever which completely fixed the above issue.
    - Lowered the brew pressure to 9.5 BAR
    After all of this still getting source / not nice tasting coffee.
    I spoke to. my roaster Small Batch about it and they confirmed I had the right recipe, 1:2 in 27-30 seconds. They said they think my brew pressure was way too. high, they told me they bre at around 7-8 BAR. I thought that was way too low based on everything I've read here, but last night I gave it a shot.
    Once I lowered to 8, the first shot I pulled tasted so much better.
    Why does brew pressure impact the taste of coffee so much?
    Also, I'm really glad I've been able to fix the grouphead with the drain chamber functioning perfectly again.
  • Birkin7
    Hi, 4 weeks ago you first posted your problem with the VBM, numerous posts, suggestions, ideas to fix etc the problem still exists. Time to call in the cavalry and find an experienced espresso tech to sort your machine out.
    I would well and truly be having serious caffeine withdrawal symptoms by now.
    Maurice
  • roosterben
    When I had the some problem in my Rocket Giotto I bought a new 2 way solenoid (still sitting in my parts box as it wasn't the problem). After pulling apart the group a few times and checking each item against the old and re-assembling exactly to the parts diagram it started flushing correctly (as below I may have had to reposition the lever handle/cam but can't remember).
    Your lever if you pulled it off and replaced the o-rings and cam when you rebuilt your group, maybe you reassembled at a different position so it is not moving the E61 valves correctly which is causing a) Drips from not sealing properly and b) Not flushing properly from the backflush due to the lever handle or cam being out of position.
    When checking the lever I find it easy if you have removed the top nut on the E61 group to loosen the top spring with the mushroom. Then is it easy to check the position of the lever cam and make sure you have attached the lever handle in the correct position.
    Per your above comments you can easily remove the lever cam and have a look at it.
  • anthonypiccolo
    It's weird, after replacing the pistons with brand new ones with new gaskets, when I backflush and put the brew lever back down, I still don't get that pressure release and water exiting the drain chamber, I remember it would almost squirt out as the pressure was released. I read this online. Perhaps it's something to do with this as I have a brand new 3 way valve in my E61...
    Also in response to your comment @roosterbean - I'm sure the few drops leaking every now and then is probably because I potentially put a valve incorrectly, but I don't think I did. But the backflushing issue has persisted before I replaced these parts and continues to.
    Could it be the operating cam is worn down and therefore it never engages properly to allow the water to go through the drain chamber to begin with and open those valves?
    My group head won't flush when I put the lever down
    • Move the lever up and down and see if resistance is felt in any direction from the cam moving between actuators (valves). If it will not drain, and not much resistance is felt, remove the bottom of the E61 group head and inspect the actuators. They may be broken, or ground down from poor maintenance that the cam does not make contact with the top of the actuator.
    • Remove cam and inspect for flat spots. If the cam is ground down it may not be making contact with the actuator.
  • roosterben
    Well if it is dripping while making coffee and not backflushing properly you either put it together wrong or a part is not right.
  • anthonypiccolo
    Originally posted by roosterben View Post
    Re the drip from group and backflush not working normally, did you check that each E61 valve was specific for VBM Domobar Junior. The E61 group is a general design but each manufacturer has slightly different implementations. So if you bought a CoffeeParts E61 kit, not all the components will work in every E61 machine. If you have chucked out the old valves, pull the group apart and put each valve side by side with the old ones and make sure they are 100% identical. Other possibilty is springs in the wrong spot or valves upside down.
    Yep, I bought it from Talk Coffee and got the specific VBM parts.
  • roosterben
  • anthonypiccolo
    Ever since I did the full e61 service, the temperature at the group gets to 105C and when I flush it's far too hot.
    I think because the group hadn't been serviced it may have been running cold, and that's when I moved boiler pressure up to 1.3 BAR from 1.2 - I guess now that the grouphead is serviced I can move the boiler pressure back down to 1.2
  • Jackster
    Can you do a video?
    Shouldn't be leaking out the drain when making your brew, maybe a seal pinched, or something.
    Try tasting the brew water without any coffee. Wait till it cools so you can taste it properly. If it's not nice, there no way you can make a good brew.
    Are you saying your chemical backflush doesn't make froth out the drain? How can that be? Is it maybe backflowing into hx. That would likely give a gross taste after. Lol
