Rocket mozzafiato water flow increased
  • Rocket mozzafiato water flow increased
    Hi I have had the mozzafiato for over two & a half years without any issues and have it plumbed in with a Brita c150 finest inline filter which I have changed every 12 months but I now have a problem..
    around a week ago water stopped flowing to a trickle through the group head, after a little look on the internet I took the top nut off the group to look at the restrictor and I found scale over the top off it covering the tiny hole so I used a socket to take it out and give it a 10min bath in citric acid which cleaned it and now I have to much water flow..
    I ended up taking the mushroom out and gave that a clean and put on a new o ring on but still getting way more water flow,
    I am getting just on 300ml of water out of the group in 15 seconds which I think is almost double to what I was getting when I first got it and checked it a couple of years ago.
    any ideas?
    oh just to mention I can’t get a pleasant coffee out of it and I find myself looking in the cupboard at a jar of instant coffee ?
    What sort of pressure are you seeing with a Blind Filter in place?
      It is still reaching 9 bar and holding, I had a go at raising & lowering it one or two bar but didn’t seem to change the flow rate.
      a friend said that he had a new restrictor as a spare so just changed it out and absolutely no difference ??
      Been thinking about getting a e61 flow control device for a while for fun but now it may be necessary..
        You mention you changed the mushroom o'ring, did you know there are two sizes?, if you fit the thinner one where a thicker one was, you may get higher flow rate
          It was ordered for my rocket and looked the same maybe a little thicker due to the original one flattening due to time.
            Quick update, I ended up purchasing a flow control device and I have fixed whatever problems were happening.
            have it set at 200ml/ 30sec and am once again happily caffeinated ?
