VBM water issue
  • leemobilecoffee
    commented on 's reply
    yeah ithink maybe block somewhere and try descaling the machine. or could another possiblity is the opv problem
  • Beenz
    Originally posted by leemobilecoffee View Post
    i dont think it is pump issue. Did you pull the lever fully up? When there is no water comes out, does the pump running? I think could be your microswitch .
    Thanks, It seems to have settled down. Working fine.
    When I pulled the lever up, the pump engaged and ran, but no water came out.
    So probably not a pump issue?
  • leemobilecoffee
  • Beenz
    Originally posted by EspressoAdventurer View Post
    Beenz would you measure / time the flow.
    200 -240g in 30 sec is an avge baseline.
    Check at the mushroom and gicleur as to their state / condition.
    If your comfortable / competent with AC240 remove the side panels and observe the water lines for obv signs of scale buildup.
    What area of Aust are you?
    Std water is described as ( hard etc.) ?
    Thanks for the questions.
    I'll pull apart the mushroom and have a look.
    The machine looks to have no obvious issues. Photos attached.
    It's been working fine since I posted.
    The normal amount of water is coming thru. No tubes where it is less.
    I live in Sydney, just moved and had it serviced early last year.
  • EspressoAdventurer
    Originally posted by Beenz View Post
    Hi There,
    I'm after some ideas what could be the issue
    I have a 2012 VBM Domobar Super with a factory fitted rotary pump.
    When i turn on the lever, the pump engages, but sometimes the normal amount of water comes out, sometimes about half, sometimes almost none.
    So, I'm assuming it is a pump issue....
    Any suggestions?
    Thanks in advance
  • Beenz
    started a topic VBM water issue
    VBM water issue
    Hi There,
    Any suggestions?
    Thanks in advance
