How to decal Blanco BCM6X machine
  • How to decal Blanco BCM6X machine
    I have one of these machines, bought it secondhand but no instructions on how to decal it.
    Do you mean descale?
    You can find the Installation and Use Manual as well as the Service Manual for your machine here.
    Java "Manuals are handy things to have" phile
    Toys! I must have new toys!!!
      Thanks for that, I have gone through both of the files and it does not tell you how to do the descale, just say end user can do it. So either I have missed it or if not any idea of how you perform it.
        Hey it's a bit of a mission to descale the boiler. To descale the brewing circuit is easy. Just put descaler in the reservoir and then brew for a few seconds wait 5 minutes then repeat 3 more times then run water through till it doesn't taste of descaler.
        • To descale the boiler you have to take the whole machine out and then drain the boiler through the pipe that it fills from, then run descaler in and leave it sit then repeat. Then run water in, probably also some bicarbonate soda then water till it tastes right.
