Spent a bunch of hours on the leaky beast which is a Wega Mininova vibe pump machine. When I got it was full of teflon tape and leaking from just about every fitting, I have managed to remove most of the crap and fix all leaks.
I am down to a single leak in the pipe from steam pressure gauge to boiler. Best I can tell is it is 4mm copper pipe 47 cm long (uncoiled) and has 1/8 BSP female nuts (and pressure fitting) at each end. One end has cracked behind the press fitting or the nut has cracked from over tightening.
Wega parts diagram indicates the following description;
WY52002097 TUBE D-4 L.470
I assume D4 = 4mm diameter
This is a similar tube (but not the same), not sure if it is allowed to link to HomeBarista;
https://www.home-barista.com/repairs...be-t22977.html
Is there any one around who can either locate one in Australia or make one up?
I will try and remove the but tonight but not sure as it may damage it even further.
