I just upgraded to a dual boiler from the oscar ii. I really miss the steam power of the oscar. The only thing I don't like is I think the pressurestat is really average in the oscar and the musica for that matter. You can't adjust it and it has a pretty wide heat band. My original oscar definitely had a more consistent brew temp and I didn't need as much of a cooling flush. The cheaper e61's will come with a much smaller boiler at a guess so you'll have to accept less steam and it won't be quite the work horse. Honestly though if you loved the musica you'll love the oscar
Isomac / Breville / Lelit / Simonelli / ECM
I use a Musica at work and a Lelit Mara X at home. The musica might not have the build quality of the Mara X e61 but the musica has awesome steam that the lelit doesn’t come close to in X mode, it starts good but runs out of steam towards the end.
But if you are doing mostly espresso shots then steam might not be too important to you.
Hey all,
Would appreciate some advice.
Looking for a home machine for 4-5 espresso shots per day. Maybe 1-2 lattes or caps.
I had a Simonelli Musica for a few years, was happy with it. Looking for another machine now.
Ideally I'm at the $1500-$2000 mark for new, or $1000-$1200 for used.
For that range I have seen quite a few options, including Isomac Tea Due, Breville Oracle/DB, Lelit (most of them), Simonella Oscar brand new (with OPV) and some ECM's also.
Can anyone help me rule a few of these out or narrow down?
I have two Compak grinders, so should be fine for grind quality.
Thanks!
