Hi all, just found this forum as I was searching for information about the replacement control board for a Giotto Classic pre 2000 machine. I suspect from the diagrams I've found online for these models that I may have a control board that is not the original and someone has replaced it with a non standard board for whatever reason (probably couldn't get stock).
The current control board is playing up and I need to replace it. The board currently is a Gicar 1-CNO-1SC 9.1.65.00v0 (image attached) which is a discontinued model so I can't get this as a replacement. I suspect it is not the correct one anyway that should be installed.
From the manuals I've been able to find (thanks in part to this forum), I've found that the Pro.Elind A190004275 is, maybe, the original control board and the correct one that should be installed in this machine.
Can anyone confirm this as It would be good to get it all back operating as it originally did.
Documentation for this I found available here at Rocket Giotto Classic, Premium, and Premium Plus Exploded views and Parts List on page 11.
Any clarification on this would be appreciated.
