I have the V1 Pro 800 and I don't think you will be disappointed. V2 is even better styling but basically the same functionality.
To Lever or Not to Lever, that is the question.
Update.
thanks to all who offered support and suggestions, it was really appreciated.
currentlytrying to get everything working together. I’ve got 3 different beans.
so far I’ve got the 18g coffee shots working great for a straight espresso in around 30sec.
but I’m have trouble getting a strong coffee taste from flat white. Different beans make it slightly better but still milky. Reduced milk is an option but I don’t want to offer a 1/2 cup of flat white.
how do I get the coffee stronger without over extraction bitterness? The 18g does seem to fill the basket any more than half way and the extraction while the right amount in 30s doesn’t have the solid single stream and crème I’ve noticed in videos.
do I need more beans than 18g, or should I pull the lever twice to lengthen extraction and get the bitterness that will be offset by the milk? Any suggestions appreciated.
ps I have the PID set to 120c
I have the same combination as you. My suggestion would be to use the dose you are happy with (18g) and grind finer. Ignore the 30 sec rule and have a longer extraction, 50 sec to 60 sec should get you to the point you are aiming for. I would also make sure you tamp firmly with the Pro 800. I tested quite a few baskets over time and found the VST produced the best shots for me so that maybe another thing to consider.
- Likes 3
Agree with Beanz's response.Originally posted by Meinoz View Postthanks to all who offered support and suggestions, it was really appreciated.
currently trying to get everything working together. I’ve got 3 different beans.
1/The 18g does seem to fill the basket any more than half way !
do I need more beans than 18g?
2/how do I get the coffee stronger?...... without over extraction bitterness?
The 5c test will help assess just how high the 18g dose sits in relation to the maximum dose available for your basket.
2/ As Beanzy said a longer shot with ahigher extraction ratio, look for hazelnut tones in the crema as a basic visual sign, plus greater amount of grams in the shot out (i.e. an 18g dose try at leat 36 towards 40g taste and then try 44-45g.
Milk, quality, stretch and volume of added to the espresso is another thing to look at further on.
GL
Higher volumes may well work.
Just to clarify my comments I was sticking with 2:1 ratio so for 18g I would still aim for 36g out but getting that over a longer time duration ie the 50 - 60sec. I was not meaning to suggest greater volume
The finer grind and longer shot time extracts more from the coffee.
At times when I change coffee and have ground a little too fine I get longer extraction times and stronger shots so I am basing my advice on my own observations. A few ideas to play with, the Pro is so much fun to use any excuse for pulling shots is good news 😊
- Likes 1
