Mazzer mod
  • #16
    Re: Mazzer mod
    martybean: I love to have yr template. Can u draw me one when u get back your dividers? Thx~~I can wait~
    Tony
    • #17
      Re: Mazzer mod
      I will try to get time,shouldnt be a problem.However my grinder is a MazzerSJ clone so the template might be slightly different.
      • #18
        Re: Mazzer mod
        Thx martybean~~Just wondering what is the difference between MAzzer SJ clone and mine? Is the doser is slighty bigger in the SJ?
        • #19
          Re: Mazzer mod
          Tony my grinder holds about 500gms in the doser your grinder holds about 200gms. The doser on mine has a diameter of 120 mm .I have managed to find a compass and have made a little coffee spout out of brass if you want its yours.
          • #20
            Re: Mazzer mod
            I have started using the Schectermatic : described Here I printed it on a sheet of clear plastic used for overhead projectors, only did it yesterday, so far it is working well and being clear plastic it looks alright.
            [edit]I should add grinds can catch around it but are easily dislodged by a bit of a wriggle up and down[/edit]
            • #21
              Re: Mazzer mod
              Looks good, I think with the one I made the fingers may have to be removed. That is much simpler
              • #22
                Re: Mazzer mod
                Just printed out the spout temp on card paper and fitted it. Doesnt seem to fit that well in my grinder, the opening in the grinder isnt round also it sits much closer to the fingers.
                • #23
                  Re: Mazzer mod
                  Mazzer opening is not round, it takes a bit of fiddling to get it in, maybe yours is a bit different to the genuine. I originally used a paper one the plastic seems to work better.
                  • #24
                    Re: Mazzer mod
                    I may have to get some plastic film to print on and give it a go.
                    • #25
                      Mazzer doser spout mod
                      I added this mod to my mini yesterday and its going gangbusters.
                      Early on I had it block up in the funnel (perhaps a side effect of dosing too slowly at one point) but otherwise, its been smooth sailing from then on.
                      Its throwing slightly to the right now, but not enough to be any real concern.  The fall is wonderful and the grinds look less clumped than they sometimes did before.
                      And.... the mess is nearly gone!!!!  I can clear the doser entirely and have the mess drop pretty much directly between the fork arms instead of all over the bench!
                      Oh, and the result in the cup is better (I know, how strange)
                      • #26
                        Re: Mazzer mod
                        Jamver,
                        Can you post a pic of your mod?
                        Also, Im thinking of doing the "doserless" mod - ie replacing the doser with a 2litre bottle.
                        There are detailed instructions here:
                        http://www.home-barista.com/espresso-grinders/mazzer-super-jolly-2-liter-bottle-doserless-modification-t3545.html
                        But those are for an SJ, and Im wondering if the Mini doser attachment is the same. Looks to me like it only has two screws. Anyone know for sure?
                        • #27
                          Re: Mazzer mod
                          flatwhite, I reckon the plastic bottle looks a bit cheap. Id look more at a black funnel like juanjo uses in this vid (http://www.youtube.com/watch?v=NrnIfQ8q22o&feature=channel) and the paintbrush pushing it through the mesh should get rid of all the clumps. just my 2c ;D
                          • #28
                            Re: Mazzer mod
                            Youll find some pics of my mod on my Facebook Coffee Album which is available here:
                            http://www.facebook.com/album.php?aid=52768&l=77511&id=568853523
                            (you dont need a Facebook account to see it - its public)
                            cheers,
                            James
