Cunill Tranquilo Problems....
  • Cunill Tranquilo Problems....
    Hmmm,
    With the potential for it having a bent motor shaft Topher, Id be giving this away to someone who wants to have a go to see if it can be resurrected :-?
    Re: Cunill Tranquilo Problems....
    But it seems the bottom burr has a slight wobble to it
    Does the shaft wobble or just the plate. If just the plate the screw holes may be a bit oversize, allowing the plate a bit of wriggle room, try loosening the screws and centre the plate.
      Its hard to tell. Its only a slight wobble to look at, that I can really only see when the whole assembly is together. I cant see the shaft wobbling on its own, but I think that would be really hard to see. Any ideas on troubleshooting this?
      There seems to be some give in the positioning of the plate with the vanes, the metal spacer/washer and the flat washer that sits inside the burr - so it could be anything.
      Anyone got ideas??
      MODS: Maybe this should be moved into the grinders section until I sort this out???
        Agreed....
