I have found Massimo to be a great grinder except for the motor noise. The motor in itself is not the problem its the motor noise coupling with the bench top through those hard little rubber feet that is the problem. Maybe new feet would have fixed it but In Bunnings today I picked up a set of 16mm rubber tips, a tight fit indeed over Massimos feet, a bit of Vaseline would have helped but I got them on without. Massimo is now very well behaved with his new boots, just some motor hum and the sound of sharp plates cutting through fresh beans. ;D
