K3 Touch Coffee Tastes Different to EM0480
  • K3 Touch Coffee Tastes Different to EM0480
    Im struggling a bit coming to grips with the difference between the K3 and the EM0480 as far as coffee taste is concerned.
    The K3 tastes acidic the EM0480 doesnt - same beans of course.
    From what I understand, the acidity has to do with the roast and not the grinder. So I guess this means the K3 is able to highlight the difference between good and inferior beans whereas the EM0480 cant.
    Anyone care to comment :
    Re: K3 Touch Coffee Tastes Different to EM0480
    Rusty,
    Have you managed to dial them both in to the same pour time, give or take a second? If the K3 is running the pour faster, then it will taste acidic/sour.
    Also take not of the colour of the crema.
    I bought a mazzer mini a few months back, and honestly, I cant tell the difference in taste when theyre both dialled in. The Mazzer is much quieter, easier to use, but in terms of difference in taste, I dont think theres a diff.
      Do you mean between the Mazzer and the K3 or the Sunbeam :-?
        Originally posted by 30323E3636383F22510 link=1244163879/1#1 date=1244164628
        Rusty,
        I went from the Sunbeam to the K3T and now have the K3 Pro with doser. From memory I, too, do not think I noticed a dramatic difference in the taste of the coffee if everything was dialled in correctly between Sunbeam and K3T BUT... K3T quieter, less messy, less waste. K3T also a much more "substantial" grinder, heavier duty, built to last...
          Maybe I made a mistake in buying the K3T
          Should I sell it after less tha a week and stick with the Sunmbeam :
            I would like to add that I also think the K3T may have offered better consistency. The Sunbeam seemed to get itself mixed up from time to time. I would have to grind really coarse and then attempt to dial-in again. Never an issue with the Compak.
            I thought my K3T was a GREAT grinder.   I would never have considered going back to the noisier messier Sunbeam. The only reason I went to the Compak doser model was to try something new. It had nothing to do with being dissatisfied with the K3T.
              If you bought a Ferrari and couldnt handle it for the first few days, would you go back to your old 4 cylinder Datsun?
              Or would you persevere and end up enjoying all the benefits of the better engineered vehicle?
                Rusty,
                While the sunbeam is a good basic grinder, theres many benefits in going for something such as the K3. Stick with it, work on getting your technique. As with any new piece of equipment, theres a learning curve. YOu might have to revisit the basics again to make sure youre heading in the right direction.
                And I meant having the K3 and the sunbeam dialled in to the same pour time. I only mentioned my mazzer mini as an example.
                -ACog
                  Thanks for the advice ACog.
                  Looks like my bean supply will deplete over the next few days
                  Probably at the same rate my caffeine level increases :P
                    OK! I standardized the pour between the two grinds and bingo! I could hardly tell the difference in taste.
                    It was a matter of stopping the shot just as the colour lightened.
                    So what have I learned from this episode :
                    Technique, technique and technique
                    Thanks for your input
                      The challenge now is to get it tasting better than the Sunbeam...
                        I guess its not just about making coffee - seems theres always a challenge pursuing the God Shot
                        Once I achieve that whats left :
                          Achieving it every time ;D
                            this to me has been an interesting thread.
                            From reading some threads on CS, it is always reiterated "its all in the grind" and a better grinder will produce a better shot, but from reading this, thats not necessarily the case (or is it potentially other factors - ability of ones palette to discern differences etc).
                            I guess it could be some other things you aim for (consistency being perhaps the key one) but if the timer on the K3T is as useless as an ashtry on a motorbike, then again, consistency has to come down to technique rather than just equipment.
                            Ive hopefully organised a trial of a mazzer (SJ or mini, depending on what my roaster has spare) for a week or 2, but for me, if I cant tell the difference in the cup, it would be a hard sell (to the minister of finance) for the upgrade
                            Maybe a weekend of side by side shots is called for.....
                            Sen
                              Hi Senator,
                              I look forward to reading your report
