Seeing were all into grinder maintenance, has anyone attempted to dismantle the conical burrs on the Iberital? The problem is removing the nut which holds on the top burr --- turning the nut also turns the motor shaft on which it sits, defeating the purpose.
I want to remove it to give the burrs a thorough clean.
Robusto
Robusto
. I think the less often you disassemble the component parts of a machine, so long as its consistent with being able to maintain it properly, the better. Unnecessary disassembly and reassembly will ultimately run the risk of causing more problems than it solves....
