Hard to adjust mazzer
  • Hard to adjust mazzer
    It is getting very hard to adjust my 5 year old mazzer mini.
    You need to apply some real force to the adjustment collar to get it to turn very slightly.
    Could it be the springs are getting very stiff or could i havei cross threaded the collar on the last clean i did.
    I figure if i cross threaded it i would have noticed it, but it spins on easily enough until it gets to the springs which apply the pressure, then it get harder from there.
    Re: Hard to adjust mazzer
    Get some food grade grease and apply it to the thread. I doubt you have cross threaded it, It would be obvious and imo a thread of that size be very difficult to do.
      Originally posted by 71696C6C796843717D722A2B1C0 link=1253146638/1#1 date=1253146835
      Yep a good strip & clean apply a little grease
      Adjust grind while machine burrs are spinning will also make it easier
        will give it a shot.
        KK, yes i make it a habbit to always have it spinning whilst making adjustments
          Actually,
          I wouldnt put any grease in there. A better idea would to grab some powdered graphite from a local locksmith or hardware store and then brush a little into the threads of both parts. Should work great and will not be a magnet for ground coffee particles...
            amen to that Mal Also... be careful while adjusting the collar while grinder is running (especially if youre winding it in after a dismantle). Much damage to be done if it reaches Zero by accident!
              If you are reassembling after a dismantle there would be no need to have the unit running because there should be no beans in it to cause a jam.
                thanks for the tips, will look in the hardware store for some powdered graphite.
                Just to clarify, i only have it working when adjusting grind, not after a clean and re-assemble
                  I think i let this one go too long now.
                  Today i finally decided to pull it all apart and give it a good clean. Apply some graphite to the threads to make it easier to adjust.
                  WELL WELL WELL
                  i can not turn it at all now It is stuck so badly that i broke the little lever that screw into the side to help adjust.
                  Thats not an issue ans can easily replace it, but there is no hope of getting the adjustment coller off now
                  any tips?
                    I hope you did not cross thread the collar when re assembling
                    If not & In any case you dont need the adjuster rod to unscrew it
                      WELL WELL WELL
                      any tips?
                      Sorry to hear it John....Sounds like you have cross threaded it to me It should move even without a lubricant.
                      I am thinking some protective rubber and a very big vice? Hope there is not too much damage.... :-/
                        i had a funny feeling i may have cross threaded it last time, and i dare say this confirms it.
                        I was looking at a new grinder as you know but did hope to sell this one. Not looking good now.
                        Can i spray anything onto the threads to get it off, then have it inspected.
                        Also any way i can tell if its been cross threaded
                          Possibly a lubricant/dispersant and then it will need a real good clean...
                          My advice though, take it to Anthony at Genovese. They are an importer and will have the right gear to do the job properly....
                            2 possibilities on this
                            1] If you have cross threaded the collar it will be rare that it would be possible to wind the collar all the way down
                            2] If it is wound down all the way its possible that its locked the top & bottom blades together
                            PM sent
                              thanks again guys
                              will now give the lubricant a go and see how i go
                              Sort of agree with KK, if it was threaded, it should have been very hard if not impossible to wind it all the way back down again.
                              fingers corssed
                              have sprayed it and will now let it soak in for a while
