A couple of questions about adjusting & grinding with my new K3 Touch.
I read somewhere you should only adjust the grind when the grinder is running (grinding)... is this correct? Does this mean adjusting without the grinder running will damage the burrs?
Also I have been loading the hopper on a grind by grind basis - and grinding out the remaining couple of beans before releasing the hopper gate to allow the next load into the burrs... will grinding without beans damage the burrs?
Apart from a few design quirks I am loving this grinder. Results in the cup have been great and my pours have dramatically improved.
