Sunbeam EM0480 grinder not fine enough - possible to mod?
  • #31
    Re: Sunbeam EM0480 grinder not fine enough - possible to mod?
    Originally posted by 660C534846210 link=1256346023/29#29 date=1257715528
    Originally posted by 58777E7C6B547877787E7C747C776D190 link=1256346023/25#25 date=1257565331
    Yes -  90deg bend? and 25mm
    Bunnings have clear silicon tubes 70mm long that would do the trick, and look a lot better than a white pvc pipe.. I bought the wrong one (25mm) but the 20mm would probably work.
    Should just hit up sunbeam for one
    YES..
    Also the clear PVC makes teh static worse.... As per my link above...
    http://coffeesnobs.com.au/YaBB.pl?num=1217234963/48#48
    The pvc pipe works well and you can always paint it :-)
    • #32
      Getting one sent out, fairly good support Sunbeam have going on there.  Dont know why youd bother painting a PVC pipe as it would still look crap. Not sure about static its just to direct the grinds from going everywhere..
      • #33
        AM is sure.
        • #34
          PVC plain or painted looks better than clear tubing and
          Originally posted by 5F637E656F6E796C646F0B0 link=1256346023/32#32 date=1257771006
          AM is sure.
          Trust me... The static is the issue... Looks... Well...
          Had many things in life that looked good.... But give me performance any day...
          And if ya lucky...... Sometimes ya get both..
          • #35
            Will see how the sunbeam one goes when the send it out.
            Not too fussed, it doesnt make as much mess since adding the washer and dont want to get too obsessed with this so should be fine
